Hi All,
I've been trying to use the TV Episodes Rip Guide posted by Wulf109 to rip Sopranos Season1 Disc3 to one DVD including the menus and extras.
Followed the steps exactly, and burned the VIDEO_TS files using RecordNow Max.
Everything works great until you start trying to play the episodes.
The first episode plays part of the way through. The remainder of it shows up under episode 2. Episode 3 does not play, and the chapter points for it also do not work. Episode 4 starts near the end.
The question I have is this:
Is this caused by the way I burned the DVD using RecordNow Max, or did I screw up earlier in the process?
I ripped the DVD to the hard drive w/DVD Decrpter in File Mode.
The tools I used are as follows:
-DVD Decrypted [3.1.4]
- Make-It-Easy [0.16]
-IFOEdit [0.95]
-DVD2ONE [1.0]
I was hoping this process would be faster than ripping episodes 1 at a time and then re-encoding them using TMPGENC, but I've now spent 8 hours on this, LOL.
Results 1 to 1 of 1
Nutty1
Vista DVD Playback Problems
By JMMac in forum Software PlayingReplies: 14Last Post: 16th Dec 2010, 14:39 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 12:01 -
playback speed from extracted dvd menu audio
By juetenglord in forum AudioReplies: 5Last Post: 22nd Feb 2008, 06:38 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 10:19 -
By thelethal in forum Video ConversionReplies: 7Last Post: 4th Jun 2007, 15:08
