Im haveing problems with XP freezing completly when trying to encode Xvid -> SVCD using Vdub and TMPGenc plus.
i tried a few versions of both progrms and XP still locks up????
Has anyone else had this problem or know what the problem is?
This problem is apparent before and after format?
Strikes me that it is one of 2 things:
1) software out of date- ensure you have downloaded all the updates for your computers, this includes VIA drivers, Win XP Service Pack 1 etc! be careful installing the latest version of direct x because some of your software may not support it! (or if you have installed direct x 9, maybe this is your problem!)
2) hardware prob- encoding is very demanding on your CPU, it therefore generates a huge amount of heat and so if your PC has insufficient air circulation (eg air intake & outtake as well as heasink & fan) AND/OR your heatsink & fan combo is running your cpu too hot and so it is freezing as a result!
if you can get hold of a hardware monitor (download from your motherboards website) then try running the software that you do (so your pc is at full load, working at max capacity) and then, 10 mins into it (or b for it freezes). if your cpu is running above 60 degrees then this is highly likely to be your problem (in theory they can run at 75 but this does lead to sever stability problems!) If you are running above 55 degrees then i would reccomend better ventilation (just removing the side panel of your case will do as a short term solution) or a better quality heatsink/more powerful heatsink-fan
c ya m8
Picture freezing
By Toes01 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Jan 2012, 14:52 -
Freezing Problem!!!!!!!!
By vickynash in forum Newbie / General discussionsReplies: 20Last Post: 26th Jun 2010, 21:37 -
Computer Keeps Freezing
By Squid_uk in forum Newbie / General discussionsReplies: 14Last Post: 11th May 2008, 07:43 -
Computer Freezing up
By ruknabard in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2007, 17:52 -
Why are my movies freezing?
By bigmatt72401 in forum DVD RippingReplies: 10Last Post: 6th Aug 2007, 05:41
