Results 1 to 9 of 9
  1. I have a DVD movie image file created with Nero. The image was created from a DVD-R disc. When i try to burn this image with my ND-1100 DVD+R writer it won't fit, there is not enough room. The image file from Nero (.nrg) have the exact size of a full DVD-R disc no matter of the real amout of data the original DVD-R contained.
    Does anyone have any idea how to burn this image or edit .nrg files or mount them or whatever??
    Tanx.
    /REX
    Dec 2002
    Scotland
    Hmm i'm not sure why it isn't working for you, tha max size for DVD-R and DVD+R is 4.36GB. Unless the disk you made a image for is a DVD9 it should work.
    If it's DVD-Video try creating the image with DVD Decrypter and then burning it onto DVD.
    If it isn't try creating the image with CopyToCd and then buring it.
    P.S. I like to use RecordNow Max to copy DVDs and I have found no problems with it what so ever.
    Hope this helps
    Barry
    God's in his heaven... All's right with the world!
    Robert Browning (1812 - 1889)
  3. Tanx for the tips BarryHL!!
    The problem is that i no longer have access to the "original" DVD-R disc, so im stuck with this image created with NERO. The size of the image is 4,38 GB (4*707*627*164 byte) just a litte to big. The funny thing is that i have burned a image exactly like this one with a DVD-R burner and it worked perfectly.
    Downloading RecordNow Max Demo to give it a shot!
    Dec 2002
    Scotland
    Use a program that can mount the image (I think alcohol 120%) can do it) and then use DVD Decrypter to rip it.
    Or if the DVD isn't encripted use a program to view into the image (like Iso buster or WinISO)
    Hope that helps.
    Barry
  5. Winrar can open up a *.iso files. And then you can extract the files to a location of your choice
  6. I had the same problem but it was all DVD-R no DVD+R nero can not open file's larger then 4gig you can use ultraiso to open it up then burn the vob files like how you would rip a DVD I think it's better to rip DVD then to make image files
  7. Member SaSi's Avatar
    Jan 2003
    Hellas
    Some DVD+RW disks have slightly larger recording areas. I have recently purchased a couple of Sentinel DVD+RW's and the total recording area is reported by Nero as 4,484,138. Perhaps an idea would be to burn onto a rewriteable (if mounting the image fails).
    The more I learn, the more I come to realize how little it is I know.
  8. Problem solved!!
    I used UltraISO to convert my .nrg (nero image file) to .iso. The result is a file with the same size as the movie. From 4*707*627*164b to 4 503 358 122b. Then i used RecordNOW MAX to burn it..works like a charm!!
    I must thank you all for your help and especially BarryHL and spiderman2k1 for the exellent software tips! Keep up the good work. :thumbup:
    /REX11
    Dec 2002
    The Great Northwest
    Hi Guys
    It has been asked a thousand times and as many different ways but once again this time for the record.
    * Question What is the size of a DVD+/- R/RW, is it 4.7 like it says?
    * Answer DVD 5 is a single layer DVD that stores up to approximate 4 700 000 000 bytes and that is 4.37 computer Gigabytes where 1 kilobyte is 1024 bytes (4 700 000 000 / 1024 = about 4589843KB / 1024 = about 4482MB / 1024 = about 4.37GB). So why does it says 4.7 GB on the DVD Rs? Because they are not using Computer Gigabytes, they use standard kilo where 1 kilobyte is 1000 bytes. DVD-R/W and DVD+R/W supports this format.
    Dd
    (;-{> Dd
    Strength and Honor
    www.dvd9to5.com
    www.dvd9to5.com/forum/
    "For every moment of truth there's confusion in life"
    Black Sabbath/Ronnie James Dio
