Is there a very simple way of burning and mp3 diretly to cd and not changing to wave format first? Please reply if you have any good suggestions. Thanks
Are you wanting to burn an audio cd?
If you are on a Mac...the right choice
, just pull the mp3s into Toast and burn as an Audio Cd.
If you are on a PeeCee
, I believe the newer versions of Roxio Easy Cd Creator accepts mp3 files directly for audio cd burning.
You can use nero for that. It will convert to cd audio in realtime while you burn.
i think that is why the call the MAC burning program TOASTOriginally Posted by tgpo
just kidding :P -
baldrick, I have tried doing that with nero but it only converts it to wave format than burns it.
Burn as data then as tenders says...I thought that you wanted a cd audio.
Can I directly burn a DVD-R from my camcorder?
By debbyandbill in forum Newbie / General discussionsReplies: 3Last Post: 21st Jan 2010, 21:17 -
Is it possible to record directly to a computer?
By RevenantOne in forum Newbie / General discussionsReplies: 5Last Post: 14th Aug 2009, 15:05 -
best freeware to burn directly between 2 burners?
By spiritgumm in forum DVD RippingReplies: 4Last Post: 20th Jul 2008, 09:45 -
HELP can I transfer directly from camcorder during a live shoot to DVD burn
By Lind Lou in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2008, 13:47 -
Can you burn directly from Sony hdr- sr1 to blue ray disc, How?
By pistol pete in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Mar 2008, 04:49
