When capturing at 640*480, Huffav yield around 800M/s, which is about 48G/hr. I tried LEAD MJPEG, Lossless codec works even worse. I only have a 60G HD. So I need a codec which still treat every frame as keyframe but yields <40G/hr. It will be better <30G/hr. It will be even better that it can be encode later to SVCD,VCD and DivX quicker.
BTW: It seems impossible to keep "loseless", but I want to keep the most quality with the size restriction :P
I used the DV codec (MainConcept) to obtain good quality and easy editing, because not having a DVD burner, I store the master version on a DV tape.
In this way the editing is very fast and the size is the usual 13 Gb/hr.
To obtain this i had to change processor up to Athlon 1.2 GHz.
Also check the field order because I had to change it in the codec, coming from Hi8 tapes.
Hope it hepls
Riccardom
Question - how to make ffmpeg use mjpeg codecs when it encounters 4CC code
By bf4648 in forum Video ConversionReplies: 0Last Post: 12th Oct 2011, 17:53 -
What's a good way to capture online video with good quality?
By newtie in forum Capturing and VCRReplies: 4Last Post: 19th Feb 2011, 10:41 -
Anybody used FFDshow Mjpeg codec for capture?
By davexnet in forum Capturing and VCRReplies: 8Last Post: 31st Oct 2010, 01:27 -
unable to get date code from DV capture
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 15th Dec 2009, 16:24 -
Phillips DVD+R, 16x, media code: CMC MAG. M01...These any good?
By i am x in forum Newbie / General discussionsReplies: 1Last Post: 15th Mar 2008, 11:26
