Since 3 Days the New Firmware 7.22 is released. You can get the next few Days at:
http://www.ianc.net/philips/index.shtml
Cya
Sturchill
Results 1 to 11 of 11
I really don`t know.
Maybe you can now FF/RW the S(VCD)`s.
Try it!
Cya
Sturchill -
I have a little Problem with the Upgrade.
The same Problem occurs with the original Upgrade CD.
Maybe it`s because i switched my Player Codefree with my One For All.
I put in the Disc.
It counts DRA 1, DRA 2, DRA 3, DRA 4
Then the Display shows "DLA ERROR" -> 2 Times
The Player shuts down himself
Then the Player goes on alone
The Display shows "DLA 1"
And the Done
So i still have the same Firmware on it (7.12).
Anybody got the same Problem and know`s how to solve it?
TIA
Sturchill -
I got the same error philips dvd 711 can't even upgrade to 7.12.
tried it on 2 philips dvd 711 2x dla error.
Firmware orig from philips on cd send to me by mail.
tj -
hi
i have upgrade my Philips DVD 711 from firmware 7.12 to 7.22
i have used a CDRW and i burned the CDRW with EASY CD CREATOR
there was no problem while upgrading.
i have tested to FF/RW an SVCD made by myself, the problem subsist.
bye
I upgraded to 7.12 on my Philips 711 and I CAN FF/RW SVCD's at 4X and 32X speed. Kicks right back in and plays when I press play.
I use Tmpgenc12a and VCDimager and burn with CDRwin.
I see no reason to go to 7.22 unless someone finds some cool new feature. -
I have a phillips 711 , try to opgrade firmware 7.03 did not work, like to make xvcd , what settigs do i need .
anybody ho like to help is welcome.
Hi,
What is the differences between version 7.22 and 7.12?
Is there any advantages/ risks in updating?
Thank you very much,
Philips 3560 Firmware Update?
By Moontrash in forum DVD & Blu-ray PlayersReplies: 4Last Post: 6th Jan 2012, 18:39 -
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
Philips DVP5965k/98 modified firmware?
By chongbian in forum DVD & Blu-ray PlayersReplies: 4Last Post: 27th Nov 2008, 01:59 -
Philips 5980 firmware hack ???
By Milo Mills in forum DVD & Blu-ray PlayersReplies: 0Last Post: 27th May 2008, 11:48 -
Philips HTS3450/37 Firmware????
By ezdell in forum DVD & Blu-ray PlayersReplies: 2Last Post: 14th Nov 2007, 16:20
