Hi,
I have some captured AVI files from VHS. I want to remove the Audio from that files and insert the new audio. How can i do that.
Thanks,
Mursand -
- Open AVI in Virtual Dub
Select "No audio" under Audio
Select "Direct stream copy" under video
Save
You now have an AVI with no audio.
...or, before saving,- Select "WAV audio" under Audio to choose the audio (in WAV format) you want with the movie.
Select "Full processing mode"
Select "Compresion..." and choose the audio comression you want to use (mp3?)
/Mats - Open AVI in Virtual Dub
Best Program to Remove Audio from VOB and insert another Audio
By Zhuge Liang in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2012, 02:42 -
How do you insert an audio clip between audio clips in AVS Video Editor
By johnharlin in forum EditingReplies: 1Last Post: 19th Apr 2011, 01:17 -
Removing/Adding Audio from Avi
By Anurag in forum AudioReplies: 7Last Post: 8th May 2009, 11:33 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Removing Second Audio from XVID avi File
By mdesai in forum AudioReplies: 2Last Post: 25th May 2007, 09:51
