Results 1 to 13 of 13
    Jul 2001
    One Step From Hell
    Is there a DVD>SVCD guide anywhere. Looks like a cool program but I can't figure out how to load the d2v file into it. Is there a way to frame serv to it??
    Thanx
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    you can directly frame serve to it with v-dub or if using dvd2avi , use vfapi on the d2v file
    Jul 2001
    One Step From Hell
    I thouhgt i tried that and it didnt work.
    Ill try again when i get home tonight and let ya know.
    Thanx
    -How do I load a vob into vdub then frameserv?
    Jul 2001
    One Step From Hell
    NOPE, When ever I try to load my fake avi file into MC Mpg Encoder it says "No Video Data Found"
    Also, How would I use vdub to framserv to it. VDUB wont take my fake AVI or a vob?
    Thanx
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    sounds like you dont have vfapi reg's correctly ...
    btw ... you should be able to directly load VOB's into MC anyway ..
    Jul 2001
    One Step From Hell
    I got it to work, I didnt have the vfapi reged like you said.....Thanx
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    you can even load the VOB into the audio and it will take the first ac3 file --
    Jul 2001
    One Step From Hell
    This program looks pretty cool. Fast as hell. I dont like the no x-pass but oh well.
    Thanx for the help
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
    multipass coming next version - but its single pass has very good "look ahead"
    Jul 2002
    Scotland
    Please can you explain how to "use vfapi on the d2v file".
    Thanks.
    dlb.
  11. anyone tried succesfully frameserved an avi file trought vdub or avisynth to MC? green screen always for me!
  12. Член BJ_M's Avatar
    Jul 2002
    Canada
    no problem at all -- trying changing reader order priority in MC
  13. try several times and no luck. my version is 1.31, latest.
    thinking in reinstall s.o. 3 days trying this to work well.
