Hi
At the moment i'm using DVD2SVCD software to convert my avi files. I use CCE to encode. The problem is that it converts to 2 bin and cue files if the bitrate is over 76mins. I am hoping to purchase a DVD recorder soon so was wondering how I could convert an avi file into one BIG file that would fit onto a 4.5gb dvd disc.
Can I still use DVD2SVCD to do this or have I to use CCE alone???
Many thanks.![]()
take a look here for some ideas that might help:
https://www.videohelp.com/convert
Got two .avi files and need to pare them doen to fit on one dvd, help!
By BroCraig in forum ffmpegX general discussionReplies: 8Last Post: 25th Aug 2009, 12:35 -
AVI to DVD - Movie doesn't fit on screen
By tmac2085 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 10:18 -
Problem converting avi to vcd using CCE
By Hittz in forum Newbie / General discussionsReplies: 4Last Post: 2nd Dec 2007, 20:27 -
why won't my avi fit on a dvd-r
By bigwheels103 in forum Newbie / General discussionsReplies: 3Last Post: 24th Oct 2007, 21:08 -
How to get large avi to fit on dvd while keeping quality
By BrettO in forum Newbie / General discussionsReplies: 6Last Post: 3rd Oct 2007, 08:54
