I have to avi file with the same video and codec resolution but i don't know why the audio is different and i can't join the tow file.
Do you know some method ? Can you explain me step by step.
Thanx in advace.
Hi,
1. First of all you have to check the audio conversion. You could do so by the program Gspot that is in the tools section.
2. If you have the desired conversion on the computer then open VirtualDub. If you don't just download the compression file from the tools area. It should be there.
3. Instead of me writing in here just go to: https://www.videohelp.com/divxtovcd.htm and read the "Audio Extracting" part.
Zapta
joining avi files
By dugen in forum MacReplies: 1Last Post: 11th Jun 2011, 12:47 -
joining avi
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Sep 2010, 07:13 -
Joining avi's
By Frisco656565 in forum Video ConversionReplies: 5Last Post: 9th Sep 2008, 21:29 -
joining avi's
By php111 in forum EditingReplies: 15Last Post: 5th Aug 2007, 10:05 -
Joining two AVI's???
By Kayfabian in forum EditingReplies: 1Last Post: 17th May 2007, 18:07
