I captured a video from a digital source with PAL DVD quality and I want to edit the video, but for some reason Premiere doesn't let me import the MPG file. I can't import MPEG2 for some reason. Does anyone know how I can overcome this problem. I think I have to download the MPEG2 codec from somewhere but I don't know where from, can some please help me...
Officially, PREMIERE DOES NOT SUPPORT IMPORT of MPEG-2 FILES on the TIMELINE
unless you use a LOCAL CAPTURE CARD capable of capturing to this MPEG-2 format on the very machinwe you are editing on...
Practically however, I've done this, and edited MPEG-2 no problem...
The TRICK seems to be...UNLESS you have such a capture card installed...USE only matching bit rates together on the time line and don't try to import ac3 files(premiere usually chokes)..use MPEG-audio...and voila! you can edit MPEG-2, and output MPEG-2 if you have 6.5 or a plug in to 6.0
BY THE WAY what you are trying to do is possible with a number of third party plugin import PROGRAMS for importing MPEG-2 to premiere such as MPEG-Marvel and i believe M-2 edit has such a product tho' I've not tried either
LOOK in adobes horridly huge knowledge support base
use term "import MPEG-2"
Continued failure at importing audio from a DVD into Adobe Premiere Pro CS5
By msp1518 in forum AudioReplies: 0Last Post: 11th Aug 2011, 15:44 -
Importing video/audio into Adobe Premiere Pro CS3
By JCW2001 in forum EditingReplies: 26Last Post: 15th Jan 2011, 21:39 -
Trouble Importing avi file into Adobe Premiere
By Top Gun in forum Newbie / General discussionsReplies: 8Last Post: 18th Jul 2010, 14:21 -
Problems Capturing/Importing Video into Adobe Premiere Pro
By Texas in forum EditingReplies: 3Last Post: 15th Apr 2010, 02:56 -
(update)Importing .mkv to Adobe Premiere CS4
By yodnnee in forum EditingReplies: 1Last Post: 23rd Jan 2010, 09:58
