I have downloaded several AVI movies, but I can't do ANYTHING with themI have been told i should have downloaded them in MPEG/MPG format, but i can find any
I have :
Nero/Nero Express,
G-spot (which I have no idea what any of it means),
Easy AVI converter (which cant read any of my movies),
AVI2VCD (again, i have no idea about),
and MPEG writer (yes u guessed it....????)![]()
Now if ANYONE can help me, AT ALL, It would be appreciated no end![]()
Im SOOOOOOOOO frustrated!!!![]()
Read some of the guides, particularly how to convert and author. They are on the left of this page.
Essential software IMHO
Virtualdub, good for checking for bad frames, and decompressing audio with variable bitrate. TMPGEnc cannot handle audio with VBR so you need to save it uncompressed (its all in the guides)
TMPGEnc, excellent mpeg encoder
Nero or VCDeasy for authoring and burning.
Be prepared to do a fair bit of reading, to get good results you need to put some effort in. -
I got the decompresser and compressed a 700MB avi movie....... it is now 1.8GB
I am totally lost now
How am I supposed to get that onto VCD?
gawd! am i thick or what
Dy :wave: -
Yep, I think you probably are!Originally Posted by Dymonds
Anyway, do what Craig Tucker suggested, read some of the guides on this site as well as the sections under WHATIS. Download the software needed (much is freeware or shareware) and try a few things. When you come unstuck (which you will) feel free to come back and ask specific questions. If you want useful answers remember to give as much detail as you can about your source material, what you have done so far and where it seems to go wrong, including details of any error messages you getr. Thay way people have a good chance of helping you. -
Food for thought:
A 700 MB AVI that is a single movie can be a LOT bigger in MPG. You can hit roughly 45 minutes/800 MB for for MPG. It's not as 'efficient' as DivX/XviD. However, 1 CD AVI's generaly are HEAVILY compressed, and it really shows on a TV.
I'd suggest you backup your own DVD's, the end results are 10x better than converting an overcompressed AVI.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
That's true. So many people believe that converting divx movies to vcd will magically give them the quality back. No matter what you'll never get the quality any better than your starting source. You can not add quality, only substitute...like adding a blur.
no sound with newly downloaded .avi file
By JediPM in forum MacReplies: 7Last Post: 30th Dec 2008, 16:29 -
Downloaded AVI to DVD problem
By karlh10 in forum Video ConversionReplies: 6Last Post: 5th Aug 2008, 15:55 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 21:25 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14 -
AVI File Downloaded from torrent
By mps in forum Video ConversionReplies: 1Last Post: 10th Jun 2007, 11:54
