Hi,
I captured 2 hrs of VHS quality video to AVI format ( using huffyuv codec ).
I captured the AVI files into 5 files each of 4gb size.
Now how can i make the VCD complients mpeg1 ( step by step, because i am doing this first time ). And also how can i split this files into No of CD's.
Video Format : AVI
Size : 352 x 288
FPS : 25 PAL
Thanks,
Mursand -
There are lots of AVI to VCD guides under HOW TO/CONVERT.
/Mats -
HI,
My problem is i am having mulitiple AVI files. From single AVI to Mpeg i know.Thanks,
Mursand -
This is more a question of "how do I join AVI before encoding?" then? If so:
Open the first AVI in VirtualDub
Add the second AVI with "Append AVI segment" (under file menu)
Keep up this 'til you have enough time for a VCD
In VirtualDubs view, this is now one AVI (and can be save out as such, if that's your wish).
Frameserve from VirtualDub to your encoder.
All AVIs must have the same encoding, resolution etc.
/Mats -
thanks mats..
Tell me which is the best way to encode.
I mean append all the AVI file into one single file then
encode in tmpgenc
OR
Append the AVI file and frameserve to tmpgenc directly.
If i append all the AVI files and then choose the option of Save as AVI file, will loose the quality.Thanks,
Mursand -
I'd frame serve. To save them out as one huge (20 GB!) AVI sounds like a waste of (temporary) HDD space and time. To boot, you can resize, add logos, subtitles,... before letting TMPGEnc take care of it. Encode to 2 VCD's by setting the source range in Virtual Dub and make 1 mpeg for each VCD.
/Mats -
Hi mat,
when i try to frameserve from the virtual dub to tmpgenc i am getting the error say can't open.
I tried the changed the VDR extension to AVI still the it shows the same error.
where i'm wrong when frameserving.Thanks,
Mursand -
Many guides on that subject here too!
/Mats
How to make an AVI better quality (keeping output still as AVI)?
By Dogpoundz in forum Video ConversionReplies: 15Last Post: 22nd Sep 2011, 00:12 -
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
How to make flashes play normally in VCD?
By blair in forum Video ConversionReplies: 5Last Post: 20th Oct 2009, 05:14 -
How do I make an AVI from a Still
By WuTangDvD in forum Newbie / General discussionsReplies: 11Last Post: 27th Feb 2008, 11:41 -
How to make an autorun VCD in English please!
By jimiir in forum Authoring (VCD/SVCD)Replies: 10Last Post: 8th Aug 2007, 22:56
