I am planning buying some new software for burning movies and music and was wondering if anyone had any recommendations?
I'm not sure if I've posted this in the correct forum but any help would be appreciated.
Thank you![]()
I suppose the obvious choice would be NERO BURNING ROM.
This software will do what you looking for.
I would also suggest that you download the Demo to try it. -
I will second Nero
cdrecord + cdrdao are 2 excellent pieces of software, that has never failed me.
/Mats -
I use RecordNow Max which costs about half as much as the other programs and works flawlessly.
Recommendations for Blu-Ray Burner with LTH media support
By TBoneit in forum DVD & Blu-ray WritersReplies: 12Last Post: 19th Oct 2010, 17:43 -
External Blu-Ray Burner Recommendations
By derekwc in forum Authoring (Blu-ray)Replies: 0Last Post: 12th Aug 2010, 23:35 -
Recommendations for DVD Burner
By dqtus in forum DVD & Blu-ray WritersReplies: 9Last Post: 11th May 2009, 12:59 -
I Need New Burner Recommendations Badly
By Jonathan in forum DVD & Blu-ray WritersReplies: 7Last Post: 13th Sep 2008, 17:05 -
DVD Burner Recommendations
By ctdvd in forum DVD & Blu-ray WritersReplies: 4Last Post: 31st Aug 2007, 20:37
