Ok. I rebuilt the PAL engine (again) by PAL-a-fying the NTSC engine (like I did before) since the NTSC one doesn't seem to have this mysterious problem.
I will let you all know in the AM if in fact my fine Polish Flick, Pan Tadeusz (Polish audio, english subs enabled) actually runs end-to-end like it always seemed to in testing.
I am making a VCD, as my TiBook is *much too pokey* to do anything else in a reasonable amount of time.
If it works, then as far as I'm concerned its fixed, and will be released as 1.5.2
-K
Well, well, well.
Here's what I got.
No hanging at the audio stage. Multiplexed just fine.
It didn't split to final files however. I'll try to figure out why this is, but it will take awhile...my machine is but so fast.
-K
Wifi Woes
By mmitcham in forum ComputerReplies: 6Last Post: 18th Oct 2010, 00:59 -
VC-1 Encoding woes...
By madmillington in forum Video ConversionReplies: 17Last Post: 16th Sep 2010, 17:14 -
virtualdubmod woes
By mac71671 in forum Video ConversionReplies: 3Last Post: 12th May 2010, 21:50 -
Forty-Two requiring I install BSD Subsystem on Leopard
By Berkey in forum MacReplies: 6Last Post: 12th Dec 2007, 11:13 -
.BIN/.CIN still baffling part 2
By DarkPhoenix77 in forum MacReplies: 10Last Post: 10th Oct 2007, 22:53
