I can't get my 695MB 90 minute movie to fit on one cd. (I want to make it a VCD.) I've looked at the "Newbies guide to fitting a movie on one cd using TMPGEnc", and I've followed instructions there, but my movie still keeps coming out at over 900MB.
Here's what I have my settings at, they are like ones I found in the guide:
Under Video Tab:
Stream type: MPEG-1 Video
Aspect ratio: 4:3 525 line (NTSC)
Frame rate: 23.976 fps
Rate control mode: Constant (CBR)
Bitrate: 912
VBV buffer size: 40
Motion search precision: Normal
Under Advance Tab:
Video source type: Interlace
Field order: Bottom field (field B)
Source aspect ratio: 4:3 525 line (NTCS, 704x480)
Video arrange method: Full screen (Keep Aspect Ratio)
Under Sytem Tab:
Stream type: MPEG-1 (non-standard)
Anybody know what the problem is? The movie is in XVid avi format, does that make any difference? Oh, and if this helps, I have version 2.59 of TMPG.
Thanks so much for any help, it would be ever so greatly appreciated!!
upgrade to 2.510, In the discution area for that guide, it was point out that 2.59 has a problem. Using prior versions or the newest version will work correctly.
Exo -
found a reference to change the 'directshow multimedia file reader'.
TMPGEnc...Option...Environmental settings...VFAPI plug-in....right click 'Directshow Multimedia File Reader' and increase priority to 1 or 2.
Combine a 2 disc movie into one video_TS folder?
By dreborn in forum Newbie / General discussionsReplies: 9Last Post: 2nd Aug 2009, 07:42 -
Empty DVD Disc with a movie on it ???
By macbuz in forum MacReplies: 8Last Post: 8th Jan 2009, 13:42 -
any way to grab movie and soundtrack only from a BD? (not all-disc)
By sapiendut in forum Blu-ray RippingReplies: 3Last Post: 8th Sep 2008, 19:03 -
fitting more than one movie on a dvd
By LaLuna in forum Newbie / General discussionsReplies: 4Last Post: 21st Jan 2008, 19:15 -
2 disc movie to RIP and Burn
By naftalim in forum Newbie / General discussionsReplies: 2Last Post: 11th Dec 2007, 13:44
