I have a video_ts folder with vob's anf ifo's and bup's that can play in windvd.
How do i convert that to mpeg2 (DVD compliant) without re-encoding. DVD authoring programs can take an mpeg2 (via demuxing) and turn it to a vob so there should be a reverse process.
Will i have to demux to m2v and ac3, join all files, then remux to mpeg2.
My final result i will use with dvdit pe to author.
Okay, maybe i should start from the begining:
I am trying to turn a 2 disc wedding video total 1:40:00 to one disc. However, each disc have a different title menu structure.
Steps i have taken (in parenthesis is the result from this step):
rip disc 1 with decrypter (video_ts with vob's,etc.)
rip disc 2 with decrypter and renamed vobs to be continuation of disc1, moved to disc 1 video_TS
ifoedit to create ifo
instant copy to turn to 4.3gb (pdi files)
pdi2iso (iso file)
isobuster to extract files (video_ts with vob and ifo, etc)
now i have the ifo and vob structure of one large movie although the timecodes are not perfect. if i play this on windvd, the time jumps back from 46 minute to 41 minute when the start of the where disc 2 takes place (what did i do wrong? should if ifoedit again aat this point?)
That's where i am; would like to turn this one movie to create my own menu with dvdit pe which accepts mpeg2 dvd compliant files (but i don't think it takes vob's, stangely).
i really prefer not to try any other author programs since i had so much probs with dvd wise.
thanks,
I did this using Ulead Movie Factory 2 ("import video" or so) which is available as trial. It worked fine.
thanks,
that did the job except 2 problems:
it spit out 13 mpg files. I used combimovie to join them but the timecodes are all messed up. Where disc 2 would have started starts at 0:00 again
shold i rerun ifoedit before running through dmf? -
Use AVi/MPEG/RM joiner 2.4 to create a big VOB.
Then use MPEG2VCR to edit what you want, save as MPEG.
Input this MPEG in DVD Movie Factory.
No reencoding.
/dragan -
If the audio is mp2 then just rename the .vob to .mpg(no re-encoding) or use DVDx to rip certain parts of the DVD to .mpg.
VOB without audio/video_ts folders to MPEG2?
By yearofthespider2k3 in forum Newbie / General discussionsReplies: 15Last Post: 23rd Dec 2010, 13:51 -
VIDEO_TS 7GB to VIDEO_TS 4GB
By klemyz in forum ffmpegX general discussionReplies: 2Last Post: 9th Dec 2009, 12:43 -
VIDEO_TS folder to MP4/AVI/MPEG2
By jwfc in forum Newbie / General discussionsReplies: 1Last Post: 25th Feb 2009, 02:26 -
VIDEO_TS to AVI and (maybe) back to VIDEO_TS
By macbuz in forum MacReplies: 2Last Post: 16th Jan 2009, 19:40 -
VIDEO_TS to MPEG2
By dizzie in forum MacReplies: 6Last Post: 4th Sep 2007, 09:19
