  1. Hi I have been using the phillips vcd toolkit and find it amazing and easy to use. I can also burn the image with gear pro without any problems, but I am using the demo of gear pro and I would like to burn the image with nero.
    I have tocsplit11 and I follow the instructions on How to unscramble the image but it does not work.
    Can someone please explain to me how to burn the with nero step by step after making a vcd toolkit image.
  2. I've figured it out now.
    After vcd toolkit made my image I opened tocsplit11 and clicked on MSC FIX and loaded the msc file I then builded the vcd toolkit image again with tocsplit still running
    and then pressed relese MSC, after this I should have exited tocsplit and then loaded the toc file but I opend the toc file without exiting and tocsplit stated that the file was not unscrambled.
    Thanx for replying Faisal.
    <font size=-1>[ This Message was edited by: Faisal on 2001-09-08 06:02:14 ]</font>
