  1. I'm following the guide to remove the Watermark from the backups I make with DVDXCopy (1.4.1, err whatever the new version is). When I remove the watermark and sometimes a few of the other useless intro things, do I Need to push 'Get VTS Sectors' before I save the deleted playbacks? Do I need to use it at all? The guide on here doesn't say anthing about it, but a few posts I've read seem to indicate that any sort of deletions require you to use it. I've made a couple of backups and they're working fine without me using it, but I just noticed that one of them indicated (Top Gun) that there are 31 chapters, but there are actually 30. When it reaches 31 it just goes back to the menu (And in case you were wondering, the widescreen version fits on one disk, just don't burn the first disk).
    Will not pushing 'Get VTS Sectors' leave extra chapters at the ends of the backups? and if so, do I even need to worry about it?
    I'm just trying to avoid any more coasters (as I had a few before I bought XCopy).
    BTW, I'm playing this on an APEX 500.
    Thanks!!!
    KenyonLord
