can somene tell me how i can convert a mpeg1 file to divx 3 or divx 5?
Results 1 to 10 of 10
Originally Posted by umair
https://www.videohelp.com/avi2divx.htm
Hope That Helps!!!:P
thanks but i tried it and it didnt work. it would bring up an error when i did save avi as and the error went by so fast that i couldnt read what it said
anyone else know of any way? it doesnt have to be a direct conversion, i can convert it to something and then to divx or however as long as it becomes a divx
puertorican138 do you know how to read? what did i say "the error went by so fast that i couldnt read what it said"
can anyone else who knows how to read help. i'll probably have to use another software other than virtualdub and nandub
Umair, I suggest that if you want peoples'assistance, you will not be so rude to them. You can take a screenshot of the screen at the exact moment in which the error message pops up on the screen by pressing the "Print Screen" button. Most likely, you do not have certain codecs needed for VirtualDub to open the video file. I, myself do not know how to correct the error message "MPEG Pack: Synchronization Error". To open MPEG-2 files, you need either the MPEG-2 modified version of VD or the MainConcept DV Demo Codec. That's all the help I can give you at this time.
"Great Spirits Often Encounter Opposition From Mediocre Minds." -
Originally Posted by T-E-M
DTS OR AC3 to mpeg1/2 4 divx or h264
By DRINGO in forum AudioReplies: 1Last Post: 31st Dec 2011, 11:16 -
H264 to Mpeg1
By Timex in forum Video ConversionReplies: 5Last Post: 5th Dec 2008, 23:00 -
MPEG1 anyone else?
By peterbuilt in forum Newbie / General discussionsReplies: 30Last Post: 11th Feb 2008, 22:31 -
converting from mpeg1 to divx
By mlkwestcoast in forum Video ConversionReplies: 3Last Post: 21st Dec 2007, 11:09 -
dvd to mpeg1
By videogirl in forum Video ConversionReplies: 2Last Post: 17th Dec 2007, 19:26
