I'm new so forgive my dumb questions.
I'm buying a DVD burner and was wondering about putting VCD's or Xvcd's on a dvd. How many min can I get on one dvd? And can I make more min with Xvcd's?
It basically is dependent on the bit rate you choose, which translate to the quality of the material. If they are currently VCDs, you could probaly get 4+ hours at that low of a quality.
To get great quality, you can normally get between 1 and 2 hours of video on each DVD.
"And can I make more min with Xvcd's?"
I don't understand that part of the question. -
I should of explained that better.
With Xvcd's u can have more than 80 min on a standard cd just with a lower bit rate. I figure u can do the same with DVD's.
Thx for the answer. -
Your are correct in your assumption. You can have more video on a DVD by lowering the bitrate just as you would with you VCDs.
Take care. -
You should be able to get about 7.5 hours at Standard VCD bitrate of 1150000 BPS.
There's a link to my bitrate calculator in my Sig. use the Reverse Calc function; fill in the blanks and hit calculate.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 06:27 -
1. Need advice: Burning DVD from Flash Drive mP4 2. DVD-R vs. DVD+R
By Ronald Vaughan in forum Newbie / General discussionsReplies: 1Last Post: 14th Jul 2010, 15:53 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 14:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 16:19
