I'm running from DirecTV receiver svideo/rca audio to an ADVC-100, I'm getting a lot of pops and hits in my audio and some minor hits in the video as well ... don't get this to a reference monitor, but I get it to the PC.
It's a Dual PIII800, lots of RAM, sblive! card, not sure what else would matter. No static really, so I'm a bit stumped.
Intention is to homebrew Tivo upcoming F1 season for personal viewing.
Check to make sure that you don't have other processes running that poll the firewire ports or the USB ports (or other programs that interrupt the flow of data.) I used to have the same problem as you until I realized that the USB cradle drivers for my pocket PC were constantly polling the USB port thus creating all sorts of mischief. After I uninstalled them everything worked fine.
Ive noticed this whilst capturing certain vhs tapes, one thing that improved it for me was to unlock the audio via the dip switch (cant remember which one). Thinking it was sync pulse problems with the tape, I tried using a video stabiliser box which did'nt help much. Something I'm yet to try is the macro disable trick by holding down the input button until the test bars disappear, I think the test bars can be seen by putting a monitor on the video out socket on the advc.
Movie only DVD9 to DVDR guide.
http://www.angelfire.com/droid/dvdr/guide.htm -
Food for thought, in my case my firewire card and onboard usb share irq 10. Cheers for that LanceSteel, I'll disable the usb for a quick test.Originally Posted by LanceSteelMovie only DVD9 to DVDR guide.
USB! Argh. My internet on this box is through USB wireless thingy. I'll give it a shot though.
LanceSteel, you da man. It was the USB, if i disconnect my Linksys wireless USB thingy, I'm fine.
thanks bro
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 19:26 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 21:52 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 09:15 -
At wits end - Capturing with ADVC-100 and audio levels are extremely low
By Towncrier in forum Capturing and VCRReplies: 13Last Post: 18th Sep 2007, 19:04
