Closed Thread
  1. I'm not really new to making VCDs, but a new user of VCDEasy. The process isn't hard, but I am having issues when the VCD hits the end. I want to make it go to the main menu at finish, and have set VCDEasy go to the main menu after finishing the 6th chapter by using "Wait 3 seconds and on timeout go to" and used the drop down to select the correct menu page.
    This seems right, but my DVD plays the VCD to the end then starts up again playing a random chapter number instead of going to the main menu. Am I doing this right?
    Another question is that in the Interactivity tab each chapter is by default set to "Play once" and then "time out to VCD END". I have been changing this to go to the next chapter, not to end. Is this correct or am I screwing this part up?
    Any experts out there, PLEASE lend a hand. Thanks.
  2. Member adam's Avatar
    Sep 2000
