I was told to check on whether the Canopus ADVC-100 is capable of providing a good MPEG stream for DVD compatibility. I would hate to change my mind about it just because of all the good things being said about the card - seems like it would be the perfect capture card besides real-time cards.
The Canopus ADVC-100 does not provide a MPEG stream, but a DV AVI stream which you then have to encode to MPEG for DVD compatibility.
I wasn't a big fan of this to start off (adding one more step to the process of course) but now that I've been capturing with the ADVC-100.. I wouldn't capture any other way...
Two thoughts of this:
You need LOTS of hard drive space.... that's a given with capturing in AVI format
And I do believe there are SOME software packages on the market that will capture and do the MPEG convert on the fly...never tried any so don't know of the quality.... -
Well, I guess that's not so bad - I was planning on editing the movies a bit before exporting them to MPEG and finally DVD. Thanks for the input.
Can I use a U.S Canopus ADVC-100 in the U.K?
By jedi55 in forum Capturing and VCRReplies: 33Last Post: 6th Oct 2012, 18:26 -
Canopus ADVC-100 - noisey/grainy and scaling?
By Gibson's Squares in forum Capturing and VCRReplies: 4Last Post: 2nd Jun 2011, 14:41 -
Canopus ADVC-100 vs Canopus ADVC-110
By tarrickb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 16th Oct 2010, 20:52 -
How should I capture my hi 8 videos with my Canopus ADVC 100 and TRV460
By eichelman in forum Capturing and VCRReplies: 4Last Post: 9th Dec 2009, 13:21 -
Canopus ADVC-100 outputs
By datman in forum Capturing and VCRReplies: 2Last Post: 7th May 2007, 18:24
