how can i make a dvd compliant mpeg so i can import to ulead movie factory.plz help
Try this:
Go to the tools setion of this site and get virtualdub.
Start virtualdub and open your avi file with it. Then do the following
Audio->Full processing mode
Audio->compression - Non (PCM)
Audio->conversion (48khz if not alreday)
File->sav wav (name this movie.wav)
When this has finished you will have a movie.wav file that is probably larger than your original avi, thats normal. Close virtualdub
Open Tmpgenc and cancel the wizard.
For your video source, select the avi file. For your audio source, select the large wav file you just created with virtualdub.
For stream type select System (video+audio), name your output file movie.mpg
Now click load and select the DVD template. If the avi file is 23.976fps or 29.976 fps select the NTSC version. If it is 25fps select the PAL version.
Click START and Encode. -
DIDIDAVE if I don't need to convert to PAL should I still do the sound forge time stretch?
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 16:10 -
How can I convert a 1080i ".TS" file to DVD-compliant MPEG-2?
By kiwisoup in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 23:04 -
By kiwisoup in forum Video ConversionReplies: 1Last Post: 11th Jan 2009, 18:53 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 07:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 11:46
