Im having problems in retaing the aspect ratio of a widscreen movie wehn i put it through DVD2avi, it automatically selects 4:3 instead of 16:9 how can i change this?
In the latest version, use the "clip & resize" option to adjust you video however you wish.
Your movie is probably 4:3 aspect. DVD2Avi always correctly detects the intended display aspect ratio in MPEG2 video streams.
Sometimes DVDs are incorrectly labeled "widescreen". My copy of Hair, for example, says its widescreen, but it's just a 4:3 image with the widescreen movie shown in a letterbox. When I pop this disc in and take a look at a VOB with DVD2Avi, its a 4:3 picture, not a 16:9 one.
For DVDs that are correctly labeled are have a true display aspect of 16:9, the package should say "enhanced for widescreen televisions" *and* "16:9."
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 10:58 -
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
CloneDVD aspect ration problem
By godftw in forum DVD RippingReplies: 13Last Post: 6th Aug 2010, 16:13 -
Aspect Ration ?'s (Avs video converter)
By VicSedition in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2010, 20:59 -
Aspect ration problems when encoding in VDub
By sd_smoker in forum Newbie / General discussionsReplies: 12Last Post: 5th Jul 2008, 11:24
