    Jan 2003
    Okay, I hope someone can help me. I have 4 mpeg2 I want to burn to DVD, I have read all over the forums that it isn't good to join mpeg2s because of the dreaded audio sync issue. But instead, I should burn them as separate tracks. My question is, how do you go by doing this? I mean how do you add separate tracks into one without the video stopping to switch over to another track. I hope this makes sense because I am new to this.
  2. Any good DVD authoring program will allow you to select all the videos and will play one after another. The better ones will make a menu so you can select the starting video but then it will usually return to the menu again.
    try the trial of Ulead DVD Moviefactory 2 at www.ulead.com to play with authoring if that's what you want to do.
    Panasonic DMR-ES45VS, keep those discs a burnin'
