  1. Is it possible to set the aspect ratio of an mpeg1 VCD compliant file to 16:9 so my DVD player will automatically add borders?
  2. Anyone? I guess I'll waste a $1 DVD and try it myself.
  3. what is the aspect ratio of the original file?
    also why are you putting an mpg1(vcd) on a dvd?
    Why not mpg 2?
    Signed
    VCD4ME
    We were all NEWBIES once and the only stupid question is the one that's not asked?
    it's already encoded in mpeg1, VCD format
  5. Member SaSi's Avatar
    Jan 2003
    Hellas
    Why not invest a couple more and buy a DVDRW? It's fine for such tests and save a lot of frustration for proof-viewing. Just a thought.
    Regarding the aspect ratio, you can't have a VCD file on DVD with 16:9. However, you can re-encode in MPEG-2, feed the encoded stream into an authoring program that supports 16:9 authoring and you're done.
    For the above, I am assuming you have a VCD file that has been "hard" letterboxed. You will need to remove the blackbars (can do that with Tmpgenc).
    The more I learn, the more I come to realize how little it is I know.
  6. unfortunately, my DVD player doesn't play RW DVDs
    i'm not going to reencode it, but i think it will display correctly on a DVD. i'll try it this weekend and let everyone know how it works out.
    it's the opposite situation here, no black bars were encoded so the 16:9 image gets stretched to fit on the 4:3 screen. you're commercial DVDs don't encode black bars at the top and bottom, they simply set the file's aspect ratio to 16:9 and your player adds the black bars for you. however, they are usually encoded at full DVD resolution in mpeg 2, not at 352x240 in mpeg 1.
