What is the best way to do it.
I have tried extracting mpgs. from vcdgearX, vcdtools, vcdcopy, etc.
When i try to author as DVD folder in missing mpeg tools, i get a segmentation fault and a crash.
in ffmpeg, i can get the file to remux after demuxing in MMMPT, but how can i join the files in ffmpeg, or can you select multiple files to remux as dvd.
any replies would help.
thanks,
rob
addendum. My problem is joining the different mpgs together. I can rip the mpgs fine and when i demux them and remux as DVD in ffmpeg, it is fine. but what is the best way to join then and not get segmentation faults or augmentation fauls when trying to demux the chunk.
I think I will answer my own reply. THis seems to be working.
I had the .bins and extracted them using VCDTools.
Also I believe using VCD Copy would extract the .dats and then just rename them .mpgs after burning with MMB
Demux the mpgs using MoreMissingTools
Then add the m2v and mp2 files to each tracks using sizzle and make an image.
burn the image in Toast.
Hi8/Video8 to DVD...to editable format...back to a DVD with a menu!
By lornarose in forum Authoring (DVD)Replies: 14Last Post: 8th Nov 2008, 16:03 -
How do I edit DVD-Video and place back into the authored DVD w/o errors?
By Stealth3si in forum EditingReplies: 3Last Post: 12th Sep 2008, 05:48 -
DVDs on hard drive for back up and play back on TV
By yadoc in forum Video ConversionReplies: 2Last Post: 2nd May 2008, 20:03 -
Back-up DVD
By syl in forum Newbie / General discussionsReplies: 12Last Post: 22nd Nov 2007, 18:39 -
Mpeg Video Wizard DVD: Burned to DVD-R, Plays back with hiccups.
By Giovannini in forum Newbie / General discussionsReplies: 13Last Post: 27th May 2007, 05:54
