When I use a menu template and then drag-and-drop a video clip onto one of the buttons to "link" the video to the menu button, the 1st frame from the clip is automatically used as the picture for the button. Is there any way to replace this image with a frame from the clip other than the 1st frame? Many of my clips have empty 1st frames and I have not been able to figure out how to replace this default frame.
Thanks...Scott
You could try just grabbing a screenshot of your movie and then using that as a button and just linking directly the scene. A bit of a pain I know, but DVD Workshop is missing many many features.
(From memory)
In EDIT mode, you can use the slider on the player to find a frame of the movie (media) that you want to capture as a frame grab.
There is/should be a button to the left of the preview screen that says something to the effect of saving the frame as file or screenshot.
Then.. when authoring your menu, you can select that "screen grabbed" frame (from the lower left attribute explorer) as a button and then drag your video attribute into it the button to link. You can also add FRAMING and SHADOWING to you newly created button.
Hope this helps.
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 03:04 -
Edit dvd menu button
By canaQ in forum Authoring (DVD)Replies: 8Last Post: 24th Feb 2010, 08:13 -
Ulead DVD MovieFactory 6 Plus Menu Option Question
By SCDVD in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 14:42 -
PGCEdit question: setting menu button highlight positions for letterbox
By Alex_ander in forum Authoring (DVD)Replies: 10Last Post: 5th Jun 2008, 12:55 -
question about dvd menu button
By HDMI in forum Authoring (DVD)Replies: 5Last Post: 23rd Jun 2007, 23:06
