I just noticed that some of the CVD's I've been cutting using TMPGenc's MPEG TOOLS, aren't splitting nicely. The audio stops at the split point, but the video plays on for 5 or more seconds, which is not as I expected, and rather wasteful. The same split/start point on the second mpeg works as expected, with no audio wierdness.
I'm thinking it may be because I don't close my GOP's, and it's an I frame thing, but I'm not sure. Has anyone else experienced this? Also, does anyone have a better split tool they use?
Impossible to see the future is. The Dark Side clouds everything...
Hello DJRumpy
Yes I have found the TmpegEnc merge cut etc. poor.
The best splitter/editor I have tried, frame accurate, is the Womble MPEG2VCR editor.
It is listed in the tools section of this site, along with other editors you could try. Womble's site is at http://www.womble.com
Cheers -
It does this to me also and all my movies are mpg2 files with closed gops
My video runs on for about 10-15 seconds
Ive posted about this before but no one seemed to have an answer
At least it's not me then. I convert my personal movies to DVD, but I often author SVCD/CVD for friends. I actually viewed one when I noticed this. Thanks for the info Sonic. I'll check it out. Is it freeware, shareware, or pay for play?
Impossible to see the future is. The Dark Side clouds everything... -
Sorry, no I had to pay for the Womble editor.
But you used to be able to download a Mpeg-1 only version for free/trial.
When I have used the cut etc in Tmpeg I haven't had more than a second or two error.
I have found it is better if you are using CBR for the original if possible.
It is much worse with VBR editing.
If you need to use Tmpeg I have found it best to select "source range" from the original during encoding. Then join the seperate files together after.
Cheers -
For all of those like myself, who are having MPG cut problems, please go to the Pegasys (if TMPG plus) or TMPG's web site if it is VCD only and place a support e-mail.
When I did that recently, they claimed ignorance of splitting problems, in my case, when I split VBR, SVCDs, TMPG freezes all of the time. Please let them know. The seem like good people, but sometimes their responses are hard to understand because of a lack of english skills.
Jon
Problem Splitting MPEG and rejoining with mplex
By jon111 in forum Authoring (DVD)Replies: 6Last Post: 3rd Mar 2011, 22:13 -
TMPGEnc MTS to mpeg-4 problem/question
By Justice37 in forum Video ConversionReplies: 0Last Post: 11th Aug 2010, 17:30 -
Splitting vob(mpeg)
By Peterrrrr in forum EditingReplies: 4Last Post: 17th Nov 2008, 13:24 -
problem splitting mpeg with tmpgenc
By jensiq in forum EditingReplies: 16Last Post: 16th Sep 2008, 09:18 -
splitting an mpeg-2?
By php111 in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 19:18
