i want to add subs to m2v file (i think with Vdub mpeg2 version)
and than fram it like Divx to tmpgenc, i want to frame it to CCE how can i do that.?
can i use DVD2AVI frame it to CCE ? how?
As far as I read on some other discussion, CCE 2.6 doesn't take the frasmeserved avi (vdr). However, the older CCE 2.5 does.
It is a substantila limit as the frameserved avi is one of the few ways (if not the only one) to reasonably add subtitles before further processing. -
convert it with dvd2avi then use a program called vfapi to convert the d2v file to an avs file so cce can accept it
(You have double posted so I've given U the same answer twice)
vcl file frame serve for avisynth
By norlane in forum Blu-ray RippingReplies: 2Last Post: 5th Feb 2011, 01:20 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
Pronto TSU9800 file that can serve the Pioneer DVR 540HX
By peterson911 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 15th Aug 2009, 04:44 -
CCE keeps on trying to change my frame rate?
By friedtofublocks in forum Video ConversionReplies: 17Last Post: 14th Dec 2007, 05:21
