  1. how do you remove subtitles from movie?
    have a svcd movie and would like to know how to remove the subtitles, have been done badly, or edit them to improve the quality etc
    what format should the movie be in? mpeg or avi
    what s/ware should I use, unable to find any "how to's" on this.
    any help appreciated, thanks in advance
  2. It depends on how the subtitles are done. If they're at the bottom in the black part of the video (assuming it's letterboxed), then you could reencode with TMPEng using crop frame to cut off the bottom and replace it with black.
    Dave
  3. subtitles are overlaid onto the film, not in "black box" area
