After converting with Main Concept if I try to import the file into Spruce up it will not let me and comes up with the following message " error in the system header- Informatio in its component elementary streams may be corrupted ". I have tried various setting within Main Concept but with no joy. If I convert with TMPGEnc Spruce Up imports with no problems but because MainConcept is faster I would like to use it instead. Anyone any ideas please
I've had no trouble with Ulead DVD Workshop using elementary streams which I'm sure is of no comfort to you. My suggestion is to look at the forums at http://www.mainconcept.com/forum/viewforum.php?f=9 Good luck!
:P Thanks for the reply but I appear to have solved the problem. I was capturing with ScrenalyzerLive 2 with capture set for type 2 DV. When I changed this to DV 1 and encoded it Spruce Up accepted it.
Rovi buys MainConcept
By lordsmurf in forum Latest Video NewsReplies: 5Last Post: 17th Feb 2014, 01:14 -
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
AVI to MPG with Mainconcept
By electrontau in forum Video ConversionReplies: 5Last Post: 1st Aug 2008, 14:34 -
Mainconcept DV Codec in VirtualDubMod
By WinSpirit in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2007, 23:31 -
MainConcept products !? use it or not..
By Harviz in forum EditingReplies: 1Last Post: 1st Dec 2007, 20:14
