Are there any capture cards that are any good at capturing in VCD compliant mpeg 1 for under £100?
I dont want to be having to reconvert after capturing.
Will the results be very good with my Duron 800?
A TV tuner would be nice as well.
The only new card in that price range is the Trueblue Action card. You can order it from Asia for $140 on eBay.
I have the ATI TV Wonder, which I got from http://www.redstore.com for less than 40 quid. You HAVE to visit ATI's home page to get Multimedia centre 7.1 (especially if you have a TNT2 graphics card!!!), as the drivers and MMC on the supplied CD are outdated. You will then be able to capture VCD compliant MPEG. My system is a Duron 800, 256MB RAM, Windows ME.
<font size=-1>[ This Message was edited by: mh2360 on 2001-09-07 14:05:39 ]</font>
Recommend a <$100 capture card for analog to lossless AVI codec
By Cheesyii in forum Capturing and VCRReplies: 8Last Post: 27th Dec 2011, 09:49 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Who makes the best USB2 capture card for under $100?
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 7th May 2009, 17:52 -
Can't Burn from Mpeg-2 to DVD (Nero Software & Pinnacle Capture Card)
By bpatters69 in forum Authoring (DVD)Replies: 14Last Post: 9th Nov 2007, 08:35 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
