  1. hello, i wasnt sure where to post this, but
    i recently burned an mpeg 2 with nero according to the svcd guide on dvdrhelp.com page. when i played the svcd in powerdvd, it played fine, but then i played it in the toshiba sd 5700 and it did not play, it said, error reading disc.
    i burned at 4x if thats any consequence, and the dvd player is compliant with svcd according to the compatibility page on dvdrhelp.com
    any ideas?
    thanks
    mohan
    Read the user comments in the dvd players list.
    https://www.videohelp.com/dvdplayers.php?DVDname=toshiba+sd+5700+&Search=Search
    They all say that you must use the vcd header trick to get svcds to work.
    http://www.geocities.com/newestmoviesencode/dvdvcd
    and burn to vcd with nero. (it will be svcd quality but with vcd headers)
  3. thanks i will try it
  4. the trick worked like butter, thanks so much, amazing quality
