I have a problem with "vcdxbuild" after I have done mpegs with chapters for many many SVCDs. I suspect that it is about my mpeg2 file but dont know what it is. Vcdxbuild does not create bin/cue file for this MPEG2.
!ASSERT: file vcd_mpeg.c: line 329 (_parse_user_data): assertion failed: (usdilen ==14)
0 [sig] vcdxbu~1 16216953 open_stackdumpfile: Dumping stack trace to VCDXBUILD.EXE.stackdump.
what version did you use? (I thought I had fixed that one with 0.7.10)
btw, this is a sign that your mpeg stream is non-compliant... I'm quite sure you used tmpgenc which inserts some self-advertising crap as user data... -
I use version 0.7.9. And with same mpeg2 files using TMPGenc 12a I've never had this problem. I encoded The family using TMPGenc 12a into 2 mpeg files, both files used same setting. The first file has no problem at all but the second.
BTW thanks, I will try 0.7.10 for the second file and let you know.
Hauppauge HVR 1950
By Wile_E_Coyote in forum Capturing and VCRReplies: 0Last Post: 23rd Oct 2011, 16:24 -
Hauppauge WinTV-HVR-950Q
By mauiwowi in forum Capturing and VCRReplies: 1Last Post: 28th Aug 2009, 21:43 -
Sony HVR-Z1U
By flexxville in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 3rd Jun 2009, 00:52 -
HVR-1800
By cathudog in forum Media Center PC / MediaCentersReplies: 4Last Post: 14th Jan 2008, 18:10 -
wintv-HVR recording
By brenjim in forum Authoring (VCD/SVCD)Replies: 3Last Post: 22nd Jun 2007, 13:42
