I just bought my second DVD burner the Sont DRU500AX I took out the Pioneer AO4 and instal the DRU500AX. The DRu500AX will not burn K Hypermedia always crash's. I never had a problem burning K Hypermedia on the AO4. Also the blank DVD+RW that came with the DVD some time's burn's some time's not. I called sony and they said they will not help me since I'm using nero and not there software. Also I'm using NERO 5.5.10.7
speak for yourself.
I just got a DRU-500AX and have successfully burned data and DVD backups on K-Hypermedia discs.
(In fact, I was expecting them *not* to work, since I got them for $1 each at MicroCenter.... but I was pleasantly surprised).
my system specs - Asus A7V mobo / 256Mb Ram / DRU-500AX as master on secondary IDE chain / Windows ME o.s.
you might want to check your system, or try again with some fresh discs.
- housepig -
I was speaking for my self. was I talking about your DVD burner my K Hypermedia also came from MicroCenter just bought them three day's ago
"DRU500AX will not burn K Hypermedia" is not the same statement as "MY DRU500AX will not burn K Hypermedia". The first statement is a blanket statement covering *all* 500AX's and *all* K Hypermedia, not just *your* equipment.
Maybe I should have put a smiley on my previous posts' first line to indicate that I was being flip, not trying to cut you down. Sorry if that didn't come through.
And I forgot in my original post, I've burned all using Nero 5.5.10.0.
- housepig -
look at these two website's
http://www.ebisschop.nl/dru-500a/
http://sony.storagesupport.com/dvdrw/mediainfo_na.htm
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
Trying to burn an mkv with subtitles, but the subtitles don't burn properly
By geramul in forum Newbie / General discussionsReplies: 15Last Post: 1st Sep 2010, 20:12 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
