I have an AMD 1.4 Ghz, 256 Ram, 30 gb HD, 6Xdvd rom (also tried with a 16x DVD rom too). I have used smart ripper and it took 40 min to rip a 80 min movie. DVD 2AVI (to make the d2v file) took 1 hour 15 min. I don't even want to know how long tmpeg is going to take. Anyone know why this would take that long on my system? Thanks
Results 1 to 11 of 11
That did it! I turned on DMA for everything and it is ripping fast. I wonder if that will help when I convert it to a d2v file. do you think? Also what does dma do exactly? Thanks a lot!
if your motherboard have via chipset, download this:
http://www.viatech.com/download/drivers/4in1432v.zip
it improved me encoding speed in cce -
DMA=direct memory access
Makes the hard drive seek info faster...i think...
Using dvd2avi will be faster witht dma on. -
DMA allows drives such as dvd-rom or hard drives to access your RAM directly instead of going to the cpu first...
DMA allows the drive to transfer directly from the HDD buffer to the PC RAM at 33MB, 66MB or 100MB per second (remember they are called UDMA-33, 66 or 100 for that reason).
If DMA is not turned ON, the drive will transfer data to the system (using the CPU power !!!) at much slower than 16MB/sec (which is the max for non-DMA). Due to the CPU involvment, there are software overhead, interrupt overhead that causes the transfer to be really slow.
How can I enabled my HD's DMA?
I have 5 hard drives, 2 of them have DMA box enabled. But the other 3 don't even have the option to enable the DMA.
C:\ (maxtor? 5400) is primary master --- DMA enabled
D:\ (maxtor 5400) is primary slave --- no option for DMA at all
E:\ (maxtor 5400) is on the 1st ide (controller card),set as master --- no option for DMA
F:\ (maxtor 5400) is on the 1st ide (controller card), slave --- no option for DMA
G:\ (maxtor 5400)is on the 2nd ide (controller card), master --- DMA enabled
Is there any way I can make the DMA enabled for those D:, E:, F: drives?
Thanks.
Please tell me you have some of those drives in a RAID configuration.... please
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Raid? No, I don't think so. ^_^
I just used a controller card for the HD. I have no idea how to Raid the drives. ^_^
Have a look at http://www.tomshardware.com, he has stuff on that somewhere. RAID and DMA
slow PC
By mac71671 in forum ComputerReplies: 4Last Post: 3rd Dec 2009, 21:16 -
how to slow down video??
By uglijimus in forum Video ConversionReplies: 4Last Post: 13th Nov 2009, 08:12 -
slow Virtualdubmod?
By mai_hnf in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 01:02 -
Slow Mo
By josel in forum EditingReplies: 3Last Post: 13th Aug 2007, 02:43 -
Slow Motion
By sbuckmybballs in forum Newbie / General discussionsReplies: 6Last Post: 21st May 2007, 02:16
