Guys I just downloaded a short clip, may I know how to burn it into a VCD, so that I can play it on a vcd player ?
P.S -The clip is in a avi format..
Creating a VCD is basically a 4 step process.
1. Download or create the video. You're already done with this part. An AVI will work just fine.
2. Convert your AVI to MPEG-1 format. Use TMPGEnc to do this. This site has links to the free software.
3. Copy the resulting MPEG-1 file to CD specifying VCD format.
4. Play the CD on your DVD player.
A couple of items to consider.
1. Make sure your DVD supports VCD format. Most do, but check. There's a link on the main page. Just type in your DVD player and it'll tell you what you need to know.
2. Some players are picky about the CDs you use. If one doesn't work, try a different type. My DVD only takes CDRWs.
3. Converting the AVI to MPEG-1 will take some time. Depending on your computer and size of the AVI file, it can take several hours to complete.
Hope this helps.
Help me, I'm a newbie
By Shadowmistress in forum Off topicReplies: 2Last Post: 19th Jun 2011, 07:54 -
Hello from Newbie
By markwaugh in forum Newbie / General discussionsReplies: 4Last Post: 11th Apr 2011, 12:13 -
Newbie needs help!!!!!! DVD to xbox 360 streaming
By JohnS719 in forum Newbie / General discussionsReplies: 0Last Post: 22nd May 2010, 07:38 -
Help a newbie with BR burning... please.... :)
By mefistofel_666 in forum DVD & Blu-ray WritersReplies: 8Last Post: 3rd Dec 2009, 16:11 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 08:43
