  1. I never can played the Princo 1x DVD-RW on any DVD-Rom or DVD player succesfully. It always play, stop, and frozen. I burned those disks using Pioneer 104 and 105 on several computers. Can you all suggest where I can get the DVD-RW reasonble price and can play? Thank you.
  2. Originally Posted by hunghuynh
    Have you been able to successfully write to and play another brand of dvd-rw using the exact same method(s) of writing?
    I have DVR-105 and I can play the princo dvd-rw in my toshiba dvd player SD2800. Sometimes it takes a while for it to start sometimes it won't start at all. I just reload and it sometimes starts. Once it starts playing it's fine all the way through with full 4.7 (4.3) movie burn.
    They will not play in my Toshiba laptop and also in my friends Dell laptop.
    Not sure why. I only use them for system backup anyways. They work fine with Stomps Backup MyPC software which backs up straight to dvd-rw.
  3. This is only the first time I am using this kind of media (I bought in a set of 25). All my recording using DVD-R play very well on almost DVD player. Thank you. May be I have to try diiferent brand DVD-RW, you have any suggestion?
  4. Princo DVD-RW sux
    I have ten I cant use, burn with no errors but nothing can read them! ;-(
    All by DVD-R are fine and all my Pioneer DVD-RW are fine...only Princo dont work, they are rubbish
    Oct 2000
    I have had decent luck with Princo DVD-RW's.
    They played on both of my set tops that can read DVD-RW, at first. But after several re-uses my Panasonic wont read them, but my Pioneer still does. Lately the Panasonic has been acting pretty finiky with all discs though.
    Also, my brother has a Philips that has a lot of trouble playing discs I burn, but for some reason it has no problem playing the Princo -RW's.
    I don't have a bad attitude...
    Life has a bad attitude!
  6. Well... I have no problem with Princo 1X -RW. I tested it with 2 set top dvd players; Cyberhome DVD-500 and Panasonic RV30.
    By the way, when I used Nero, my Cendyne (Pioneer 105) didn't recognize it but when I used CopytoDVD, it was fine.
    I ordered 25 more so I will check them and let you know.
