  1. I have been using smartripper to rip DVD's but I notice that my rip speed is fluxuating. It goes up to about 4 then down to .3 then up to 3.8 then down again. Anyone else having this problem. And does anyone know a way to fix it or a better dvd ripper? Thanks
  2. Member spidey's Avatar
    Apr 2001
    U.S.A.
    I use SmartRipper v 2.34 and it works great. I have heard it can have problems on AMD's though. Try using CladDVD. Check under the tools area for the link.
    ~~~Spidey~~~
    "Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
  3. My PC uses an AMD Duron 800, I have no such problems, maybe it's something else, try another Ripper - DVDDecrypter isn't bad...
  4. I turned on dma and it works great now. Do you guys have you HD set to DMA mode?
