Anyone know how to tell wether or not a video source is interlaced or non-interlaced. I understand the Basics of what interlaced and non-interlaced is but don't know how to tell wether or not my source video is interlaced or non-interlaced. This inforomation is needed so I can correctly encode my videos to mpeg w/ TMPGenc. PLEASE IF YOU KNOW SOMETHING POST! TIA!
Depends where it comes from - if you rip a DVD and use force film in DVD2AVI - it's non-interlaced.
If it's from a VHS tape, LaserDisc, DV camera, it's almost surely interlaced.
If it's something somebody posted, and you don't know,
visually, if you play interlaced video back on a PC - you get horizontal "stripes" whenever anything moves - if you see those, it's definitely interlaced.
But I could give you a better answer if you told me exactly what you were encoding (frame rate, Mpeg/AVI, etc.....) -
OK, This is my first DVD rip. I used SMART RIPPER for the VOB files and then used DVD2AVI for FRAMEserving. I then decided to used TMPGenc to convert the movie to VCD. I went to settings and noticed under advance that it had already selected my video as interlaced which is not typical of anything I had encoded w/ a DIVX. So this bothered me. I went to source range filter to look at some frames and I think the VIDEO is interlaced due to that fact that frames that have motion (and only these frames) have lines between the video. If the video is not a rapid moving frame it has a SOLID picture frame. I am confused because I thought that DVD's were always NON-interlaced! Any more clues about it?? Would love some more input. THANKS!
DVDs are almost always authored from a non-interlaced source, but they are usually converted from 24 fps to 30 fps by a process known as Telecine (basically adds extra frames to the movie). So, virtually all DVDs are interlaced. However, they can usually be coerced back to non-interlaced. With DVD2AVI - under the video menu, choose FORCE FILM. This will do the coercion.
Now, to make a VCD, you have a decision. You can either not do FORCE FILM, and have TMPGENC resize and possible do de-interlacing (I say possibly, because in theory, cutting the vertical size in half is a form of de-interlacing, so quite often you don't need to deinterlace). In this mode, you make a 30 fps VCD. If you do use FORCE FILM, then you have a 24 fps video, and you can make a 24 fps VCD that is NOT interlaced..... I don't know for sure if a 24 fps VCD is "legal", but I do know that most DVD players play them fine.....
Hope this helps. -
If it is NTSC, 29.97fps, and 480 vertical lines of resolution or higher, it is almost certain to be interlaced.
This works, rip with smartripper or claddvd, rip the audio with dvd2avi, use TEMPGE to put it into a mpeg and then use nero to convert it into a vcd. I haven't had any problem's with interlace or noninterlace issues.
Thanks for ALL THE REPLYS! Great stuff. I was aware of the interlacing of DVD's. I more or less need more understanding of video. I think I will have to pick up a book somewhere on it. I have made a DVD to VCD movie using smart ripper and avi 2 DVD w/ tmpgenc. The video was good but I noticed on it that there was a wierd flash effect when the MPEG played. It was not super noticeable but it does not look quite corect. It happens on moving frames on my pc and VCD player. I had started to convert terminator 2 DVD to MPEG and got the same result so I have gave up for the time being becuase I can not figure this problem out. If any of you have seen or experienced this light flashing effect in the video, Let me know and if you know of a correction. Thanks again. You guys are great!
Just a correction to previous post, I meant to say, "I was not aware of DVD's being interlaced.".
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
