Is there Any Program to Mutiplex 2 and more audio track.
cause i keep getting Buffer Underflow errors while using tmpgenc.
Using BBmpeg no errors on the same files but can't add more than 2 audio track.
HELP thanks 8)
Hmmm, apparently Cool Edit Pro v2.0 has a bunch of features that can be applied to audio files. Maybe you can use that program to fulfill your wishes.
Cheers."Great Spirits Often Encounter Opposition From Mediocre Minds." -
If your worried about the buffer errors in TMPGenc, you can take the finished MPEG,and use the Merge & Cut tab. Your not actually merging, or cutting the file, but running it through this tab tool seems to produce an mpeg without a problem. Just select MPEG-2 VBR (or MPEG-1 if applicable).
Impossible to see the future is. The Dark Side clouds everything... -
I also get those buffer underrun errors when using TMPEnc. I also got them when using BBmpeg but solved that by increasing the forced mux rate setting in the SVCD settings to be the same as it is in DVD setting (25200 I think).
Out of curiosity, what is your ultimate goal in muxing more than two audio tracks? As I understand it, a SVCD will not accept more than that, and if you are making a DVD then I would think that any DVD program that will accept multiple audio tracks (not many but the high end ones and IFOedit) will also allow you to drop them in the program as elementary (separate) streams and do the muxing as part of the final compiling process. -
cause i understand english so english for me and french for my girlfriend.
and sometimes they have commentator track or crew track so i like to add that to to my svcd.
it works with 3 in tmpgenc.
and playing it with sasami2k. i can choose them
Yes look in tools you'll find it there
its a simple svcd player that let you choose audio track with the need to burn the svcd first
what cuesheet prog do u use
By mikeo1313 in forum AudioReplies: 2Last Post: 19th May 2010, 00:03 -
which prog to capture ?
By hydra3333 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 04:19 -
Vegas compare/contrast with other prog.
By ineedhelp123 in forum Newbie / General discussionsReplies: 7Last Post: 29th May 2008, 13:40 -
recording live - prog like snapz?
By marinebc11 in forum MacReplies: 1Last Post: 25th Apr 2008, 09:30 -
What prog. encodes several videos without burning?
By Shapeup1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Oct 2007, 19:16
