Please can somebody help me!!!
I have movies that is on Vcd format and i want to burn in on a DvD...
I have tested the Updated VCD to DVD guide............ But my problem is that my movies are 3 to 4 vcd discīs.... and that are to mutch i the Dvd moviefactory prog.... Why i dont know because the actually size of my movies are 3,2Gig together on the hard drive, and in the dvd moviefactory prog the file become over 10 Gig, can somebody explaine that??? Or tell me how i can fix this......
Did you change the audio settings to mpeg audio? or else it will be pcm audio
Did you change the system to the same system as the vcd source(PAL or NTSC)? or else it will reconvert. And remember that NTSC Film(23,976) is not a dvd format, if so you must reconvert(click on mpeg settings and choose a format so it will fit on your dvd).
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 16th Jun 2010, 23:29 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Help with VCD to DVD
By bwheeler in forum Newbie / General discussionsReplies: 9Last Post: 28th Jun 2007, 02:25 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
