I am using the Hauppauge 250 with an ASUS motherboard and a P4 1.8 845 chipset based on the manufacturer's recommendation. The chipset problems and IRQ problems and audio sync problems that people have complained about do not exist with this motherboard combo.
However, I find my P4 alarmingly slow and prefer AMD CPU's. What experience has anyone had getting the Hauppauge 250 working with Athlon motherboards? What chipset has worked well? I got the card to playback on an ALi motherboard but not on a VIA based motherboard. Please post what other motherboards have worked with this card.
Does anyone know if an Athlon XP 1.8 is faster than a P4 1.8? I was told that the P4 is better at floating point operations. I am not sure if this really relevant because the 250 does the encoding on the card and then I burn directly to DVD.
I had my PVR250 working fine with my 1.4 Athlon and an Elite mobo. I've since upgraded to an XP2400 and an NForce2 chipset mobo but I haven't done any recording with it yet to see if it is still working fine.
I've run a pvr 250 on a 400 mhz AMD chip with an ALI-based MB. Realtime playback coming directly from the card's encoder was a little choppy, but disk recordings were flawless and it made great SVCD's on this machine. The CPU speed matters if you start wanting to use it's pausing / PVR / etc. functions- but the AMD should be fine, and 1.8gig is probably overkill even. Don't forget the forums at shspvr.com for info in addition to here.
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 07:54 -
Hauppauge WinTV PVR 250
By kenmo in forum ComputerReplies: 10Last Post: 28th Apr 2009, 14:21 -
PVR-250 vs Newer Hauppauge cards
By statman24 in forum Capturing and VCRReplies: 10Last Post: 21st Nov 2008, 23:13 -
new pc and my hauppauge pvr 250
By heman28 in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Jan 2008, 08:33 -
Want to replace Hauppauge pvr 250, what should I get?
By heman28 in forum Capturing and VCRReplies: 9Last Post: 25th Jan 2008, 09:25
