Forgive me for my stupid questions, I am totally new to DVD converting and authoring.
In some tutorial, they mentioned that it is best to convert avi (from DV) to video only and then use the audio extrac software to get the dolby digital audio file. But seems there is no detailed tutorial. Here are my questions:
1. If I create mpeg2 file with audio and use spruceup to author/burn, which kind of audio format will be on my DVD? PCM or mpeg2?
2. Which kind is better for DVD player, mpeg2 or Dolby digital?
3. If dolby digital is better, is there any tutorial on how to compress Dolby digital audio file from avi?
3. Will DVDit PE version accept both audio and video file and will synchronize the A/V?
4. Do I need to split/merge avi file before conversion or I can do it after conversion even if I extract A/V seperately?
Thanks for answer.
Roy
Quick question: Use MakeMKV to convert it to a streaming format?
By fatcharlie in forum Blu-ray RippingReplies: 3Last Post: 1st Nov 2011, 18:55 -
Easy Question.. Convert mkv to DVD9
By WareISChris36 in forum Blu-ray RippingReplies: 1Last Post: 21st Jul 2011, 15:22 -
question about different ways to convert srt to sub/idx
By jimdagys in forum SubtitleReplies: 7Last Post: 15th May 2009, 00:12 -
DVD Ripping then Convert Question
By frodamob in forum DVD RippingReplies: 4Last Post: 23rd Dec 2008, 22:09 -
question about no sound when I convert with Avidemux
By jimdagys in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 13:54
