I have ripped a DVD using Smartripper
Then created a d2v and wav file using DVD2AVI then
I copy the d2v and wav file to another PC that does not have a DVD drive.
I have also copied the DVD2AVI.vfp to my TMPGEnc folder on this PC.
When I try to select the d2v file in video source (using TMPGENC12f or 12i) I get cannot open or unsupported error.
The wav file under audio does open.
It works fine on my PC with a DVD drive and I'm just wondering why it won't work on my other two PCs.
One is a P2 266 the other a Pentium MMX166.
The d2v file references the vob files ripped from the DVD. As you dont have these on your 2nd PC then it wont work !
TMPGENC encoding problem
By whschlebaum in forum Video ConversionReplies: 0Last Post: 26th Apr 2011, 22:22 -
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 08:16 -
Encoding using TMPGenc 4.0 Xpress
By abdul_sma in forum Video ConversionReplies: 1Last Post: 19th Jun 2010, 07:15 -
Any way to keep TMPGEnc Author 4 from Re-Encoding video ?
By RWANDREWS in forum Authoring (DVD)Replies: 7Last Post: 3rd Mar 2009, 09:43 -
TMPGEnc Plus Encoding
By crys94 in forum Video ConversionReplies: 9Last Post: 29th May 2008, 22:23
