In TMPGEnc I get this error message saying Can not read AVI file with DV format. From the FAQ's on TMPGEnc's site:
TMPGEnc can not read AVI file with DV format.
The file is probably Type-1 DV format. The format is not supported by TMPGEnc. Type-1format has different structure from AVI format. TMPGEnc can not read the format since TMPGEnc does not support DirectShow.
To solve this matter, try to save the captured or edited file as Type-2 DV format, however, there are still chance not to be able to read the file if you are using general IEEE1394 board without codec for VFW.
And yes, I have already changed the priority in my Environmental Settings for DirectShow Multimedia File Reader to 1. My question is: Since I guess I have to convert this thing, is how? Can someone recommend a program to use to convert this. Or another solution to bypass this error. I'd appreciate all feedback please.
Look in the TOOLS section. There are two freeware converters there.
Impossible to see the future is. The Dark Side clouds everything... -
I would try putting directshow priority at +4 to see if it works.
I have TMPGEnc version 2.53 and have never upgraded. I can confirm that version 2.53 works with type 1 DV files.
Anyways, you can use DVapp or DVIO to capture type 2 files. You also need to install a DV codec such as the Panasonic DV codec.
Here's a related thread:
https://www.videohelp.com/forum/viewtopic.php?t=126850&highlight=directshow
WVC1 file format to avi/mpg/dvd
By TunkaFrankie in forum Video ConversionReplies: 7Last Post: 24th Nov 2011, 07:51 -
MP4 file (h.264 format) to avi help
By hak741 in forum Video ConversionReplies: 6Last Post: 18th Nov 2010, 01:51 -
How to watch a .avi file in a dvd player that support divx format?
By albi123 in forum MacReplies: 5Last Post: 18th Feb 2010, 09:53 -
Downloading a YouTube File into avi Format?
By solarblast in forum Video ConversionReplies: 16Last Post: 26th Dec 2007, 15:14 -
how to add subtitles to an avi file so that my dvd would read it?
By Arwen-Katie89 in forum SubtitleReplies: 8Last Post: 13th Dec 2007, 12:02
