Hi.
I just downloaded 2 movies, AVI format and wish to convert them to mpeg, using tmpg enc.
The thing is when I try to open the input file, it say's "cannot open, or unsupported"
How do I resolve this problem>?
Thanx in advance Gav.
PS if u know of any better software which can deal with mpeg1 video and audio converting please let me know, as this is doing my noodle in![]()
Can you play the avi files on your PC. Most likely you dont have the correct codecs. I think TMPGenc needs the codecs to be present as well.
The tools link on this forum can direct you to codecs. -
I fixed the opening file and converting prob now, u need to use TMPGenc v12a
cheers for the reply though
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 17:44 -
HDTV2DVD does not load up TS-file
By feilofix in forum Authoring (DVD)Replies: 2Last Post: 12th Nov 2008, 13:25 -
I have flv files I'm trying to recode but they have an enc file.
By watusi512 in forum Video ConversionReplies: 2Last Post: 17th Dec 2007, 19:59 -
How to load .ts file into HDTV2DVD?
By JR.S in forum Newbie / General discussionsReplies: 2Last Post: 15th Nov 2007, 01:59 -
Trying to load .ts file to DVCD2DVD
By movieman123 in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 18th Sep 2007, 20:37
